Micra 350SR wow!
Wala
Wysłany: Czw 27 Lip, 2006   Micra 350SR wow!
widziałyście kochane jak to lata????
Wow yeah :562:
310KM przy 6400obr i 363 Nm przy 4400
Modele - silnik z 350Z do Micry :559:
One of the last Pocket Rockets - I have come across – is Nissan Micra 350SR. It’s the latest creation from Nismo. The whole idea about this car that it has been modified to carry tweaked 3,5 litter V6 engine from his relative Nissan 350Z with specially manufactured 6 speed close-ratio gearbox. The engine from this coupe has been upgraded to output 310hp. These numbers don’t look very impressive, but if you take in to account that stock Nissan Micra weighs only 1000 kg (2204lbs) and after the modification its weight wouldn’t rise anymore than 1150kg. With those kind of horsepower and a little help from the rear driven wheels this lightweight mid-engine car could propel itself from 0 to 100 kmh (60mph) in less than five ticks (1 tick equals 1 second) of the mechanical stopwatch.
Like the old racers proverb says “power is nothing without control”, so engineers working on this project had to tweak the the suspension, that it could handle this strange (for this car) weight distribution, which is caused by the change of engine layout. When talking about speed this car is not the king, but for its class capability to hit 240km/h (150mph) is something.
Zarąbiste autko! W ostatnim "Auto Świecie" było opisywane!
lenny
auto: ceteer
silnik:: dwulitrowy
moc: dwiesciedziesieckm
na poparcie tego kilka fotek:
sebson
i nawet ladna/zgrabna ta micra :D
shorti
kurcze podoba mi sie ta micra :)
Peter
auto: Type-R
silnik:: VTEC
hehehe avatar shortiego :D
No no nissan się postaral, zajebista jest ta micra i myśle że będzie ostrą konkurencja dla clio.
Wala
nie za bardzo będzie, bo nie można jej kupić....
E to lipa myślałem, że nissan wypuści coś konkretnego w segmencie hot.
Czyli to jest tylko na tor do wyścigów tak?
moja mama jezdzi micra ;) i czasem tez Jakarti ;) mozna nawet zapiszczec w co saxxorulez nie wierzyl ;)
Wala
do kupienia jest tylko para hot czyli micra 160 SR - 1.6, chiba 110KM...i ma bębny z tyłu :D
Ciekawe czy wejdzie do produkcji, jesli tak to w jakiej postaci.
Nie bedzie konkurencja bo clio v6 juz nie bedzie :(
Poniewaz Nissan to Renault wiec urodzili micre :)
shorti
a dziekuje PETER ty i jeszcze jedna osoba doceniła moj skromny zarcik ale nie stety taki kozacki avatar wzvudzał niepokuj społeczny :D
Wala
w końcu scenariusz ten sam co z clio v6....wszystko zostaje w rodzinie :)
Kojarzy mi sie z matizem po tuningu kolegi :)
A tak powaznie, wielki szacun za taki projekt.
